Trying to set up the Botblox usb to ethernet device to host the usb connection to a cube controller.
Is this use possible ( usb fron controller i believe is a slave)?
Where is the MPLAB® Connect Configurator? It’s chapter in the documents has been removed. Can’t set Ethernet IP and Port..
