Cannot connect to SwitchBlox Industrial using ARIES
I managed to connect to the Switchbox Industrial using the Brainbox and the DFR0845. However, when I write any changes to a port and then read them back nothing changes. When I also read the Botblox Device, the Chip ID, Board Type and Firmware Revision do not populate?
Reading the datasheet, it mentions “Running SwitchBlox Industrial in a managed switch application requires configuring the IP175GHI onboard over SMI” Is this the case?
The fact that the Chip ID does not populate implies that your computer doesn’t have a serial connection correctly setup.
Have you been through the troubleshooting steps in the link below, specifically point 6.2?
We need to make sure your computer sees a COM port first, and you select that same COM port in the ARIES software.
