I’m looking for Switch POE with 4 ports. Your PoEBlox compact 360W PEO switch could be fit.
Can you just answer to this questions?
· I have seen that there are a maximum power delivered by each POE Ports, but can you tell me what is voltage for each ports?
· Secondly on your CAD there are an added PCB, named GIGABLOX nano. Can you provide me with more information about this option ?
The voltage on the ports is determined by the voltage you input into PoEBlox. PoEBlox is designed to have a 48-54 input, then that input is injected into the ports as PoE voltage (after the PoE auto-negotiation process completes).
Regarding the two CAD boards, PoEBlox is a Power distribution baseboard. It needs to be used with the GigaBlox Nano module, which provides the ethernet switching. Therefore for the CAD model, you should use the one that has PoEBlox and GigaBlox Nano together.
Let me know if that makes sense.
