I’m trying to update a UbiSwitch Rev B (BB-UBS-B-2) over UART on Windows. The updater sees the serial port, but the transfer fails. Which firmware file and command should I be using?
Use the UbiSwitch Rev B application .bin from the BloxOSLite v1.2.5 release. The SwitchBlox Industrial image is for a different board. Close PuTTY so the updater can use the serial port, then start the update within five seconds of powering on the switch. Here’s the UART update guide.
I switched to the UbiSwitch Rev B .bin, closed PuTTY, and ran the command as soon as I powered on. I’m still seeing rc=8. I’m using fs-upload. Is that the right command?
Use upload, not fs-upload. fs-upload copies a file to a destination. It doesn’t install a firmware image. Run this with PuTTY closed and leave off the destination argument:
mcumgr-client.exe upload app_dfu_BB-UBS-B_v1.2.5_20260527.bin
If upload still errors, share the exact command and its output. The fs-upload error alone doesn’t tell us whether the firmware update will work.
That worked. The switch now reports BloxOSLite v1.2.5. Is there a GUI for configuring the VLAN ports?
There’s no supported VLAN configuration GUI for the BB-UBS-B-2. Once the switch has booted normally, reopen PuTTY and use the BloxOSLite command line over the same serial connection. The VLAN guide has the commands and examples for tagged uplinks and untagged device ports.
