There is one of four potential reasons for the behaviour you see.
Reason 1: You have UbiSwitch Module Revision A
Revision A cannot run BloxOSLite management software. I checked your order and I don’t believe you have revision As. But definitely worth a quick check, take a look at the bottom of the board. BB-UBS-A-1 is revision A, BB-UBS-B-1 is revision B.
Reason 2: You have an unflashed UbiSwitch Module, Revision B, with 64Kb Microcontroller
Annoying, there are currently two versions of revision B out there in the wild; one with a 64Kb microcontroller, and one with a 128Kb microcontroller. This was due to us needing to increase the size of the microcontroller later to accommodate more functionality. Both can run BloxOsLite, but the difference is that the 64Kb version cannot be updated via UART, whereas the 128Kb can.
To solve this, you need to flash it with the firmware. Instructions on how to identify whether your board is 64Kb or 128Kb, and how to flash it can be found here.
Reason 3: You have an unflashed UbiSwitch Module, Revision B, with 128Kb Microcontroller
In this case, you simply need to flash the module with the latest firmware. Follow this guide here.
Reason 4: UbiSwitch is flashed correctly, but there’s some issue with communication
All UbiSwitches we ship now have the firmware pre-loaded. You can check if yours is preloaded if the red LED illuminates for a few seconds on startup. If that happens, and there’s still no communication, then just the usual checks (right COM port, common ground between converter and UbiSwitch, TX and RX the right way round) apply.
The red LED is here.
