Getting UbiSwitch ports working with a 1G SFP
– Rephrased from a customer email –
I want to use UbiSwitch with 1G SFPs. I heard this is possible but requires some jumper I need to change. How do I do that?
Ports 9 and 10 can be easily configured to work in 1G mode, instead of the 10G mode that the board ships with.
  1. Locate SM1 jumper
  2. Cut the track between the two pads with a scalpel.
  3. You can resolder it to re-enable 10G operation.
For port 0, the process is a bit more involved, and is detailed in this forum post.
Once the UbiSwitch management software is released, this will all be possible via software.
Further to the post by @josh_elijah above, this feature is now available for UbiSwitch in software! No soldering SM1 bridge is required! Changing the PCS mode on ports 9 and 10 can be done using the BloxOsLite CLI.
Steps:
  1. Ensure you have version 0.4.0 or above installed on your UbiSwitch. See here for public releases and here for documentation on updates over UART.
  2. Boot up UbiSwitch and then connect a 3.3V TTL UART-USB converter to open a serial console on your dev machine.
  3. Follow the instructions for setting PCS mode on ports 9 and 10 here
  4. Some examples:
port 9 mac mode 10gbaser for 10Gb SFP that does not support inband auto-negotiation with port MAC.
port 10 mac mode 1000basex for 1Gb SFP fiber.
