I think what you’re asking is, is there a preference for how each three of the 10G ports on UbiSwitch is configured.
There are 3 10G ports on UbiSwitch, port 0, port 9 and port 10.
Ports 9 and 10 can operate one of three modes:
Mode 1: SGMII/1000GBASE-X/2.5GBASE-X
Mode 2: 5GBASE-X
Mode 3: SFI/USXGMII
Port 0 can operate in one of six modes
Mode 2: 5GBASE-X
Mode 3: SFI/USXGMII
Mode 4: RGMII
Mode 5: RMII
Mode 6: MII
This is a little confusing. To simplify, there are likely only a few of these modes most people will want to use these ports in.
SFI/USXGMII is for connecting to an external 10G SFP Module
SGMII/1000GBASE-X/2.5GBASE-X is for connecting to an external 1G SFP module
SFI/USXGMII is for connect to an external 10G copper PHY chip.
Ports 9 and 10 can be configured easily as a pair on UbiSwitch, by setting the solder jumpers directly on the board JP4 and JP5. The settings for each is shown below.
| JP4 |
JP5 |
Mode |
For use with |
| 0 |
0 |
1000BASE-X/SGMII Mode |
1G SFP |
| 0 |
1 |
2500BASE-X Mode |
2.5G SFP |
| 1 |
0 |
10GBASE-R Mode |
10G SFP (default) |
| 1 |
1 |
USXGMII Mode |
External copper PHY |
By default, UbiSwitch is configured to put ports 9 and 10 in 10GBASE-R Mode, for use with an external 10G SFP. However, JP5 can be soldered, which will put ports 9 and 10 in USXGMII mode, for use with an external copper PHY.
Port 0 requires software to configure, and is by default, set to 10GBASE-R Mode.
Therefore, for an application requiring two copper PHYs and 1 10 SFP, it is recommended to use ports 9 and 10 for the copper PHYs, and port 0 for the 10G SFP.
