We are integrating the UbiSwitch into one of our designs and are planning to use all 3x 10G ports.
We want to connect two of these ports (Port 9 & 10) to SFP+ modules, and the remaining port (Port 0) directly to a SERDES interface of an SoM to operate in USXGMII mode.
I see the port mode configuration of the UbiSwitch can now be done via the BloxOsLite UART interface, which means we do not have to modify the module bootstrapping resistors.
I have a few questions:
I understand that we would only need to change the mode of Port 0 to USXGMII, as the other two ports (Port 9 & 10) are in 10GBASE-R mode by default which would work as intended for the connected SFP+ modules – is this correct?
If I configure Port 0 to USXGMII mode and directly connect the SERDES interface of the SoM to the UbiSwitch Port 0 SERDES interface, are there any further hardware considerations I need to make for this connection to work?
I know that the more common connection for the SoM SERDES interface would be directly to a PHY, but the above connection would be using it in MAC to MAC configuration. Can you confirm that your switch IC 88E6393X can operate in this way?
Since I do not have access to the switch IC datasheet, I cannot confirm the connection scheme of back-to-back MACs (i.e. Tx → Rx, or Tx → Tx). Is this information that you can provide? I have seen conflicting reports online about which scheme is suitable.
Lastly, I see your carrier board reference design did not include AC caps on the SERDES interfaces going to the SFP cage. I intend to add some 100nF to the SERDES between the SoM and the UbiSwitch and could add some to the SFP cage connections as well unless you had a reason to omit them?
