I have recently received the DroneNet product. The ethernet switch part works well standalone, however when I attempt to configure the PPP via the dronecan_gui_tool the CAN bus is not active.
I have previously configured a CubePilot CubNode successfully via CAN bus and I have extensive experience with CAN so I am confident the DroneNet CAN bus is the issue.
Anybody else experienced this issue? I am currently assuming the product is defective and will have to return under RMA, please advise.
update - I checked the CAN-H and CAN-L lines with a scope they are fixed high and low respectively, confirming the inactivity. The 5V quiescent current is 90ma.
A few things to check before assuming it’s faulty:
Power Setup
DroneNet can be powered from the 5 V input, CAN port, USB, or USART.
Make sure you’re only using one power source at a time, the 5 V and CAN rails are not power-ORed. Dual-supplying both can cause issues with the CAN circuitry from coming up.
Can you confirm the power source you’re using is not current limited? If it is, there can be brownout resets.
CAN Port Details
The CAN port is terminated by default with a split termination resistor network.
Can you confirm you’re terminating on the other side?
Firmware and Switch
After powering up, the STM32’s green/red LED should blink, if it stays solid or dark, the firmware isn’t running (could be a firmware or a hardware issue)
A typical powered and idle DroneNet draws about 100 mA @ 5 V. Your reported 90 mA is about right
The ethernet switch circuitry is a separate subsystem to the STM32 subsystem (which runs the firmware). So it is possible there’s an issue with the firmware or STM32.
If after reflashing the CAN lines are still fixed (or you don’t have the ability/setup to reflash), please let me know. It is possible that this could just be a faulty unit, but let me know responses first and we can take it from there.
