I have several question about the puck pro on the website. My application is in underground mining in potentially explosive environments. I need to sync up to 12 gige cameras through PTP into x86 compute.
Questions:
Is the puck pro the only solution botblox has that supports PTP?
Is the puck pro using openwrt out of the box?
I will have to put the puck pro inside of another explosion proof enclosure, will it be available without the IP67 aluminum casing?
The module is in development, what is the availability timeline?
At the moment there will be three BotBlox products that support PTP, these will be…
Puck Pro: A 19 port 1G/10G router with PTP capability - Release in September 2026 RouterCore: Essentially a modular, stackable version of Puck Pro; designed to be embedded directly onto a baseboard using a Samtec stacking header. - Release in December 2026 RouterCore Nano: A smaller, cheaper version of RouterCore, 7 x 1G ports and 3 x 10G ports - Release in April 2027
All the dates above are tentative and may change based on any development snags we hit.
To your other questions…
Yes it will ship with OpenWRT preinstalled
Probably not. The internals of Puck Pro are quite complex; To get that many ports in such a small form factor, the internals are quite complex to manage power dissipation, signal integrity while keeping it rugged. Supplying just the internals for your own chassis will require us to publish a lot of application information and you’ll need an expert Mech Eng on your team to do the work. This is possible but something we’ll probably only consider if the volume justifies it, or as part of a development agreement. This is more of a commercial discussion, please feel free to email me at josh@botblox.com to take that discussion further.
Now to the question of what type of PTP this will support, @peci1 makes a very good point, there’s quite a few different flavours of PTP, which adds to the confusion of using it. Many switch hardware claim PTP support but only support a subset of it.
For Puck Pro, we are going to be integrating ptp with OpenWRT. The specifics of how we do that, we haven’t decided. It’s something that will need a lot of testing and likely custom development. We are aiming to support the following PTP profiles:
IEEE 1588 PTPv2 over Layer 2 Ethernet
Delay mechanism: E2E or P2P
Timestamping mode: two-step only
Switch role: transparent clock or boundary clock
IEEE 1588 PTPv2 over UDP/IPv4
Delay mechanism: E2E or P2P, depending on profile/support
Switch/router role: transparent clock or boundary clock
IEEE 802.1AS / gPTP over Layer 2 Ethernet
Delay mechanism: P2P peer delay
Timestamping mode: two-step only, if that is your implementation limitation
