I am looking for a switch with a similar form factor to BB-GGN-A-1, but it must support PTP (Precision Time Protocol, IEEE1588). I only see that feature listed on your larger devices.
When talking about PTP (IEEE1588), it’s helpful to define specifically you are looking for. In most cases, when talking about a PTP enabled ethernet switch, this means a switch that acts as a transparent clock. When acting as a transparent clock, the switch records the dwell time of a packet inside the switch, and then updates the PTP time correction field with that dwell time.
Another factor is whether the PTP is one-step or two-step. Here is a good link that explains this further.
At present, none of our hardware supports PTP, though it is something we are working on for release in Q2 2024. Getting PTP working is not trivial and requires a fair amount of testing. It’s also only possible on our more advanced switches (UbiSwitch). GigaBlox Nano uses a more simple ethernet switch chip that cannot support PTP timestamping.
The biggest difference is in the used delay mechanism. E2E works pretty much out of the box over many switches, including the Botblox ones. Without timestamping of packets inside the switch, you won’t reach nanosecond sync, but a microsecond sync is quite possible. From the current offer, Gigastax Rugged can be configured (via custom firmware) as E2E transparent clock, adding the dwell times to packets.
The situation is different with P2P. In this case, you either have just one pair of devices and a dumb switch, which works. But as soon as you add 3rd device or a switch that is PTP aware, the sync won’t work at all unless the switch is properly configured. This is currently not possible on any BB switches, but should be possible on Ubiswitch using custom firmware.
@peci1 Did you write any custom firmware for the GigaStax Rugged in the end?
No, I did not. I just played around with the switch connected to I2C and directly wrote the register values. But when we discovered P2P is not possible without adding an RGMII-capable MCU, we gave up.
Got it. Thanks. UbiSwitch is where we’ll first target PTP because the documentation is better.
Btw, we already have a CLU working on UbiSwitch for register access, so I don’t think it will be long.
Sounds like a nice Christmas project. Could you share the CLI and relevant firmware with me? I wanted to look into it, but I’ve got overwhelmed with other work. But i should have time for this during Xmas ![]()
Are there any updates on this? Also, just to clarify @josh_elijah’s comment, are there any plans of having PTP support in Gigablox Nano (in a new revision perhaps)?
We are using the Gigablox Nano on a modified version of [2202.11055] RMF-Owl: A Collision-Tolerant Flying Robot for Autonomous Subterranean Exploration and would love to have this feature.
On GigaBlox Nano, it’s never gonna happen. The hardware lacks the key ability to do PTP timestamping in hardware.
It does look possible on UbiSwitch, and I expect we’ll have some news on that in the next few days.
Of course, UbiSwitch is bigger, higher power, and more costly…
Was there news on this?
We won’t be adding PTP to UbiSwitch in its current form. We will be implementing PTP on a more capable hardware platform that we intend to release end of Q2 2025.
Will that more capable platform be roughly UbiSwitch shaped in terms of size and environmental specs? I don’t actually need a switch before then anyway.
Yes, it will be similar form factor but not identical. As usual with our stuff, it will be super small.
Similar environmental specs? That temperature range on the Ubi is looking really nice for me.
Yes, same specs which we’ll then test with MIL-STD-810H
In Oct 24 you mentioned Q2 2025 a new capable platform (not UbiSwitch) that would be PTP compliant - is this still on track - or later in the year.
Good timing, we are now actively working on this, but Q2 2025 is no longer accurate unfortunately.
We have a new product called RouterBlox Max that will combine routing, 1G ports and PTP in a single package. We may also include GPS in this module, but not decided yet. If we don’t we’ll add a connector for a GPS module to be added.
I’ve emailed you a product brief. The ETA on this is probably Q1 2026, realistically, though we want to make it available sooner.
FYI to anyone on this thread. We’ve started this project and are actively looking for people to help us shape requirements. For example, GPS or no GPS, Atomic clock or no.
Please get in touch if you want to help us shape the product, and get early access to samples. I’m also emailing people.
Yes please, would inch by inch suffice? ![]()
Sure we’ll do it… you didn’t restrict the height dimension ![]()
