UbiSwitch BB-UBS-B-2: Failure modes and FMEA information
This Q&A summarizes an anonymized technical support enquiry about UbiSwitch BB-UBS-B-2.
What failure-mode information and FMEA data are available for BB-UBS-B-2?
We have had very few reported failures of this part. We can share a qualitative summary of the principal failure modes based on the BB-UBS-B-2 design, together with our existing environmental test results. We do not currently have a published FMEA/FMECA report available to share for this part.
At the module level, the main considerations are:
  • Shared switching resources: All ports share one switch IC, reference clock and power architecture. Failures in these common resources can affect multiple ports or the entire module.
  • Individual port connections: Cable, connector or interface faults can cause loss of link, intermittent communication or reduced link speed on the affected port. Fault containment depends on the nature of the fault and the baseboard implementation.
  • Management and configuration: Packet forwarding is performed by the switch IC. The management MCU configures the switch and can assert its reset, so MCU or configuration-memory faults can affect initialization, port configuration or switching operation.
  • Power and thermal faults: Supply interruptions, regulator faults or excessive temperature can interrupt operation. Recovery depends on the fault; some conditions may require a full power cycle.
  • System integration: The baseboard provides the Ethernet magnetics, external connectors and any additional transceivers or input protection. These need to be included in an assessment of the complete assembly.
Our environmental test report covers BB-UBS-B-1 assembled with the BB-UD1-A-1 reference baseboard. The documented B-2 BOM change is the management MCU’s move from the 64 KB to the 128 KB flash variant; the switch, power and clock components are unchanged.
The report includes temperature, humidity, low-pressure, vibration and shock testing. It also records functional interruptions under extreme conditions outside the specified operating range, including loss of the monitored links during the 150°C test, with a power cycle required for recovery. These results provide supporting environmental evidence, but do not establish statistical failure rates or guaranteed recovery from arbitrary faults.
