Switchblox's rugged memory
Hi, I’m using the switchblox rugged rev g, and was wondering how much memory it has (flash/ram)? And if so, is it accesable when using standalone? Or do I use it only when connecting the board with the SOM?
thanks in advance
Hi Layla,
The standard Rev G design uses an STM32 microcontroller with 128 KB flash and up to 36 KB SRAM. That’s its total memory, not spare storage available to an application.
When SwitchBlox Rugged runs standalone, the STM32 runs firmware that manages the switch, rather than an operating system. Using its memory for your own code or data would require custom firmware.
Rugged SOM has its own processor, RAM and storage and runs the OpenWrt operating system. When connected, Rugged SOM takes over all switch management, so the STM32 firmware is effectively no longer involved in management. It doesn’t unlock the STM32’s memory; it provides a separate computing environment for applications and files.
What are you hoping to do with the memory: save switch settings, log data, or run your own code?
