I saw you made new revision (G) for the rugged unit.
That revision looks more relevant for our applications since it has the option to use PicoClasp connectors with positive lock function.
Please if you can answer the following questions:
· Does revision G support the customer firmware you implemented in revision F to solve an issue we had?
· Does revision G already manufactured?
· Does the power input also include PicoClasp connectors?
· Can you provide datasheets for revision G?
Hi Ben,
Answers to your questions are below.
Yes, though revision G uses a different microcontroller, so we will need to update the firmware. That’s an easy task.
Yes, in stock and ready to ship.
For the PicoClasp version, the data and power connectors on revision G are PicoClasp.
Not yet, datasheet will be released later this week, I will follow up with you on that.
