Help!
My team and I have a feed from an IP camera that we’re struggling to communicate over the T1 connection between two SPEBlox (each rev F).
The entire system is shown in the attached block diagram.
Note:
Each SPE blox was properly designated as master/slave via solder bridge instructions.
The subsequent steps in the datasheet were followed successfully.
I.e. D12 flashed to indicate the SPE link was established. -
We’ve confirmed the camera feed will successfully reach the tablet when the camera is plugged directly into the Insignia USB-C to Gigabit ethernet adapter.
The SPEBlox are connected via an unshielded twisted pair of 22 AWG wires apprx. 1 ft long.
The BotBlox provided picoblade-to-RJ45 wire harnesses are used elsewhere.
We’ve confirmed the camera feed will successfully reach the tablet when the tablet and camera are both plugged into ports of the GigaBlox Rugged switch (i.e. no use of SPEBlox).
Despite all of this, when we setup the provided diagram (add SPEBlox into the mix), we do not see the camera feed on the tablet.
Any thoughts as to where we could be going wrong?
