Copied from customer email
Hello, I’m trying to connect a Gigablox to your PoEblox with a molex 1:1 picoblade wire assembly. Unfortunately there is no communication between to the two.
Here is the wire assembly I’m using.
Is there something I’m overlooking?
That cable you’re using, I believe it maps pin 1 to pin 8
This would reverse the pin order. It needs to map 1-1, 2-2 and so on.
Okay, so I need to pull the wires and reverse them on one of the connectors. I’ll try that.
Thanks that fixed it.
