OpenWRT Package Updates
I purchased a rugged-som board preloaded with OpenWRT and am having issues downloading/updating packages. I also cannot upgrade the firmware using built-in sysupgrade tools. I suspect this is because the firmware version that is loaded on the board is no longer supported.
Are there plans to update the github release to a newer version? Release v24.10.0-botblox_v1.0.0 · botblox/openwrt · GitHub
Steps to reproduce:
From CLI
opkg update
Downloading https://downloads.openwrt.org/snapshots/targets/imx/imx6ull/packages/Packages.gz
*** Failed to download the package list from
Collected errors:
  • opkg_download: Failed to download, wget returned 8.
Sysupgrade failure
System Information
Hostname OpenWrt
Model Freescale i.MX6 ULL BotBlox SwitchBlox Rugged Board
Architecture ARMv7 Processor rev 5 (v7l)
Target Platform imx/imx6ull
Firmware Version OpenWrt 24.10-SNAPSHOT r28578-fc1d7db6d61 / LuCI Master 25.070.50769~dea8d79
Kernel Version 6.6.83
Sysupgrade updates, either through the GUI or CLI, will not work. Part of the next update is to fix this.
Regarding opkg update failing: you can try using the packages created for the imx/cortexa7 target instead.
cp /etc/opkg/distfeeds.conf /etc/opkg/distfeeds.conf.backup # optional
vi /etc/opkg/distfeeds.conf
Edit /etc/opkg/distfeeds.conf
- src/gz openwrt_core https://downloads.openwrt.org/snapshots/targets/imx/imx6ull/packages
+ src/gz openwrt_core https://..archive.openwrt.org/releases/24.10.0/targets/imx/cortexa7/packages
+ src/gz openwrt_base      https://..archive.openwrt.org/releases/24.10.0/packages/arm_cortex-a7_neon-vfpv4/base
+ src/gz openwrt_luci      https://..archive.openwrt.org/releases/24.10.0/packages/arm_cortex-a7_neon-vfpv4/luci
+ src/gz openwrt_packages  https://..archive.openwrt.org/releases/24.10.0/packages/arm_cortex-a7_neon-vfpv4/packages
+ src/gz openwrt_routing   https://..archive.openwrt.org/releases/24.10.0/packages/arm_cortex-a7_neon-vfpv4/routing
+ src/gz openwrt_telephony https://..archive.openwrt.org/releases/24.10.0/packages/arm_cortex-a7_neon-vfpv4/telephony
>Run opkg update again
>You may need to comment out the core package feed if you get errors
- src/gz openwrt_core https://downloads.openwrt.org/snapshots/targets/imx/cortexa7/packages
+ # src/gz openwrt_core https://..archive.openwrt.org/releases/24.10.0/targets/imx/cortexa7/packages
Let me know how you get on.
The long-term solution is either to publish our own package feed for the imx/imx6ull target or to fix the package feeds used by opkg in build time rather than implement this fix. I will add this to the next release.
Thanks for your quick response! The package sources you listed did not work as they rely on the apk package manager. The version I am on only supports opkg. I was able to get what I needed by changing my sources to an archived source. I only needed to install one package and that worked for me, I will refrain from updating any packages as I am not sure about dependencies etc. I will keep an eye out for your next firmware release!
/etc/opkg/distfeeds.conf (remove the “..” at the beginning of the link)
Thanks for pointing that out @nbrown .
Yes, my apologies I missed that. In which case, you can try the archive packages sources or use https://downloads.openwrt.org/releases/24.10.3/packages/arm_cortex-a7/{subdirectory}
(Changing subdirectory for the specific package feeds you want)
Yes, I will be pushing this as part of the next Rugged SOM software update.
Hi everyone,
Please, indicate me if I should open a new thread for this instead of replying here.
I have the same hardware, software versions and problem as the colleague above. Originally I couldn’t run “opkg update”. After changing the package sources to the archived source, the update command works, but I still cannot install the packages I would like to. These are:
  • mwan3 and luci-app-mwan3
  • luci-proto-qmi, uqmi and kmod-usb-net-qmi-wwan
Any suggestions about how to proceed?
Thanks in advance!
José
Can go here. As it happens, I’ve finally gotten round to working on an update to this (OpenWRT 24.10.5 build) and should post within a week, particularly instructions for building and installing kmods. I’ll post the update here as well.
is the update available? I’m having trouble with the opkg updates as well
Here you go
sorry to ask but do you have a install guide for those of us not experts in this?
Yep, here you go.
