– Copied from a customer query –
I believe I have identified an issue with the LED indicators on the UbiSwitch Baseboard.
The SFP+ indicators do not correspond correctly to the Port 0-10 LED indicators as per my observations:
SFP+ in P9 → Red part of Port 10/0 LED, which, according to the manual, indicates Port 0.
SFP+ in P0 → Green part of Port 9 LED.
SFP+ in P10 → Red part of Port 9 LED, which, according to the manual, is not used.
Will the same problem occur on an external LED panel connected to the external LED header that is wired according to Figure 14: External LEDs connection in the manual?
Yes, this looks like a mistake, thanks for brining this to my attention. Let’s explore this a bit.
The way the three activity indicators for the SFPs work is a bit different to the other ports. Each SFP only has a single LED signal associated with it. This is in contrast to the other 8 ports on UbiSwitch which have two LED signals (allowing for tri-colour LED operation).
So, we have two dual colour LEDs on the baseboard (labelled Port 10, Port 0 and Port), to represent three signals. Since these labels are incorrect, I’ve relabelled the LEDs with their schematic references in the image below.
With this in mind…
- Red part of D3 flashes for Port 9 activity
- Green part of D4 flashes for Port 0 activity
- Red part of D4 flashes for Port 10 activity
It would appear that this is a mistake in our datasheet too. Thank you for bringing this to our attention. The datasheet has been updated and re-uploaded at this link, along with the hardware design guidelines at this link.
What we will probably do for the future, to make this clearer, is add three uni-colour LEDs for each SFP port.
