We are looking for at least a 4500-psi rated switch. We are currently using the 3-port nano which works great for our current topside application, but we would like to explore this option in our subsea rated equipment.
We did some R&D with the nano, but the Crystal oscillator imploded at around 3000psi.
That makes sense, the 3-port nano uses a crystal oscillator which isn’t pressure tolerant.
UbiSwitch uses pressure tolerant design so should be able to tolerate those kind of values.
Are you able to switch to UbiSwitch? It may be a bit overkill for your application.
We can look at modifying the design of SwitchBlox Nano to be pressure tolerant.
