I’m mounting the GigaBlox Nano on our carrier board witht the Razor connector but it’s not quite clear what the propoer standoff height board to board should be. I tried looking a the GigaBlox Nano Pico Con to see if that showed a standoff PN. I just want to make sure I’m allowing sufficient clearance for the board and engagement for the Razor connecotor. Can anyone tell me what the recommended board to board height is, or what the recommeneded spacer height. Alternatively what is the recommended spacer height for the GigaBlox Nano - Pico Conn stack?
Thank You for the clarification.
I am currently using the GigaBlox Nano for a project and would like to know the specifications there are for mounting. As of currently I know of the documentation with the dimensions of the board. Are there any other details regarding recommendations for mounting using stand offs and screws?
Thanks, I wound up using this solder standoff.
