GigaBlox BB-GGB-C-3: What is R4’s value, and where does U1 pin 3 connect?
Question
While replacing U1 on a GigaBlox BB-GGB-C-3, I lost resistor R4 and damaged the PCB pad for pin 3 of U1.
Could you confirm R4’s value and specifications so I can replace it? Also, where does U1 pin 3 connect? The connection is not visually clear, and I would like to restore it if possible.
Answer
We checked the BB-GGB-C-3 design files and confirmed the following component and connection details.
What replacement should I use for R4?
R4 has the following specifications:
Parameter Specification
Resistance 10 kΩ
Package 0402
Tolerance 1%
Part used by BotBlox RC0402FR-0710KL
You can use the listed part or a suitable equivalent matching these specifications.
What does U1 pin 3 connect to?
Pin 3 of U1 is the EN (enable) pin. On BB-GGB-C-3, it connects to a junction shared by three components:
Component Value Connection from the shared EN junction
R51 120 kΩ To VIN
R52 47 kΩ To GND
D3 4.7 V Zener diode To GND
How can I restore the connection if the pad has lifted?
Electrically, the connection can be restored by connecting U1 pin 3 to the shared junction of R51, R52 and D3.
Use the side of those components connected to the EN junction—not their opposite connections to VIN or GND. This restores the original electrical connection even if the pin 3 pad is no longer usable.
These details apply specifically to GigaBlox BB-GGB-C-3.
