UPDATE: Puck Mini LED Numbering Mappings for BB-RCRJSP1-37-0.4
For 37 Pin Rectangular Connector, 400mm (MIL-DTL-83513) RJ-45 and Spade Cable, BB-RCRJSP1-37-0.4.
Ethernet cable #3 corresponds to the P4 LED on the Puck Mini, and ethernet cable #4 corresponds to the P3 LED. Note the updated Micro D connector pinout diagram in Figure 3. Otherwise, the Puck Mini should function as expected.
Our datasheets for the Puck Mini and Micro D connector have been corrected. This numbering mapping issue will be fixed in newer cables.
Figure 1: #4 ethernet cable lights up P3 LED.
Figure 2: #3 ethernet cable lights up P4 LED.
Figure 3: Updated pinouts on the Micro D connector for the Puck Mini. Note the pins that Port 4 and Port 3 correspond to.
