I have a project to convert an analog pipe inspection camera to digital and I’m interested in your products, specifically the single pair ethernet device BB-SPE-F-1.
The communication channel I would like to use is an existing 75 Ω coaxial cable which was previously used for analog video transmission. The present configuration is 150 meters. I’m considering using a balun (maybe I don’t even need one) with your single pair ethernet device to realize a high bandwidth ethernet communications scheme that can use a GigE vision camera with a resolution of 2MP or 5MP (60 – 120 Mbps, utilizing MJPEG compression). No power will be utilized on the communication channel, I have a power conductor set in the tether to the surface.
I recognize the bandwidth will fall off quickly with distance. Does this seem like something that has a chance of working in your opinion or am I expecting too much?
