Please provide typical efficiencies for the 5V regulator over input voltage and load. I am particularly interested in efficiency at 12Vin, 250 and 500mA 5V load.
Sure
At VIN = 12V:
- IOUT = 250 mA: ~89–90% (≈ 89.5% typical)
- IOUT = 500 mA: ~88.5–89.5% (≈ 89% typical)
Typical efficiency vs load (Vo = 5V), and how it shifts with VIN
Approximate points from the same curve:
| Vo | Vin | 0.1 A | 0.25 A | 0.5 A | 1.0 A |
| 5V | 12V | ~89–90% | ~89.5% | ~89% | ~86% |
| 5V | 24V | ~82–84% | ~85% | ~85.5% | ~85–86% |
Out of interest, why do you ask?
thank you for the response, battery powered 5V system that is very expensive to recharge so I wanted to make sure it made sense to use Vout instead of adding an external regulator.
Gotcha, thanks for sharing!
