When designing a carrier board for the SPEBlox Module, can I use an RJ45 with integrated magnetics on the 8-wire 1000BASE-T port? Do the AC blocking capacitors affect which magnetics I can use? And does the 2-wire 1000BASE-T1 port need a separate transformer on the carrier?
8-wire 1000BASE-T: Any magnetics rated for 1000BASE-T will work. The AC blocking capacitors don’t change that, so you can use a 1000BASE-T MagJack rather than a plain RJ45.
2-wire 1000BASE-T1: The evaluation board routes the pair straight to the connector, with no additional transformer on the carrier.
The SPEBlox Module evaluation board schematic shows both connections.
