When do I need a heatsink with UbiSwitch?
See the forum post below for 100Mbps power consumption.
It will be around the same or less power consumption as using 8 gigabit connections.
You would likely be fine without a heatsink at 50C, but we would still suggest using one. (I’m assuming ground level pressure and RH between 10% and 90%
Best,
Josh
