What did we pressure-test on UbiSwitch?
Q: What would you use in a compact, oil-filled, pressure-compensated enclosure?
I’d look at the UbiSwitch Module with the UbiSwitch BaseBoard Mini. The pressure-test results below apply to the module and the standard BaseBoard, not the Mini.
Q: What did you actually pressure-test?
We tested the UbiSwitch Module and the gigabit ports on the standard UbiSwitch BaseBoard in Shell Diala transformer oil at up to 9,380 psi (about 647 bar). The published results don’t cover other oils.
Full pressure-test setup and results
