– Copied from customer issue –
My goal is to have a setup where (on only one switch):
I have a PC on port 1 with tagging being removed.
I have devices on ports 2, 3, and 4 that are sending tagged traffic.
I have another PC on port 5 to sniff the traffic to view the tagging behavior.
I am aware of this post (I need help getting tagged VLAN working on SwitchBlox Industrial - #15 by botblox_admin) but was not able to see the tagging on the sniffed port so I moved to something I thought would be simpler to understand how the settings work.
So currently I have a setup with 2 switches.
The switches are connected to each other each on port 3.
Each switch has a PC connected on port 1.
I can see traffic from PC1 to PC2 but not from PC2 to PC1.
Can you please verify my settings for the switch setup (see attached image)? The setup is the same for the second switch.
