Copied from a customer email
Hi,
We here have purchased the “harwin variant” of the SB Nano.
It seems there is an inductor (47uH) that is much larger in real life compared to the 3D model.
Using you recommended mating 3.6mm PCB connector will likely mean that this inductor will
not allow the board to fully seat against the connector housing.
Is it possible to use an inductor with a lower height? We do not use the 5V output.
