I’m currently redesigning the electronics of our subsea robots (ROV). We already use an UbiSwitch with baseboard on our surface unit, and I would like to integrate the Ubswitch module directly onto my PCB inside the ROV (in the electronics pod, with is in air at 0.8 bar).
I’m following the design guide (https://botblox.io/content/BB-AN-0004 - Designing a custom board for UbiSwitch.pdf) to design my PCB.
The design guide suggests using directly a PHY (instead of an SFP+ module) to get 10Gbps copper link, which I would like to achieve in order to communicate with our Jetson Orin AGX Industrial. The design guide asks to contact you for how to do.
Could you please advise me how best to get a 10Gbps link between the port 0 (or 9 or 10 in it’s easier) of the UbiSwitch and the Jetson Orin AGX Industrial?
Some information about the Jetson Orin AGX Industrial :
- it has only a MAC, so the PHYs can be chose on both sides
- the Jetson supports XFI (and the hardware supports SFI, but Nvdia don’t provides any support for SFI, so excepted if you have already done it and can share how to do it, we will tick to XFI)
- the Jetson will be mounted on the same PCB as the Ubiswitch
- distance between the Jetson and the ubiswitch can be around 5-8cm if needed, supporting longuer distances is a nice to have (our PCB will be about 40cm long, and it will simplify routing if I can place the ubiswitch farther away)
And 2 other smaller questions :
- for how long is the UbiSwitch Module garanteed to be available? (there is a mention of 5 years garantee from first release, but I couln’t find the release date)? How long will be the delay between anouncement of end of life and last time to buy?
- Is there any requirement on the inductance of the magnetics for the 1Gbps PHYs? can I use any magnetics rated for 1Gbps? (I’m planning to do PoE++ injection, so of course, I will take some rated for PoE++)
