What does D5 indicate? The other LED’s are all described in the spec. sheet, but D5 is not.
Hi Josh,
I’ve seen D10 blink a bunch when Ethernet is active, but I’ve also seen D5 illuminate solid green in addition to D10 blinking:
I think the D5 description is missing from the spec. sheet.
Thank you,
Any updates on this? I believe the spec. sheet is missing info on D5.
D5 indicates 1000BASE-T activity. D10 is on when there is a 100BASE-T link.
Both are on with a 1000BASE-T connection on the four pair side.
