Replacement RJ45
I need to shorten the ethernet leads to save weight. What is the part number of the RJ45 which is fitted as standard?
Hi Ricardo,
Thank you for your inquiry.
The part number for the RJ45 cable fitted as standard for GigaBlox is BB-PBRJ1-8-0.3. The standard length of these leads is 300mm. If you need a custom length, you can purchase them through the following link: Custom PicoBlade to RJ45 Cable (8-way).
Please note that the minimum order quantity (MoQ) for custom lengths is 20 units, and the lead time is approximately 2-3 weeks. The shortest length we can make is 20mm.
Should you have any further questions, please feel free to let me know.
Best regards,
Jaclyn Li
Operations Manager
Hi Jaclyn,
We are time restricted so want to re-terminate the supplied RJ45 for the same one.
MTPR-88-X-S-C6-A
