Hi!
We are using a UbiSwitch Module 3 x 10GBASE-R + 8 1GBASE-T Switch module (heatsink included + fan) integrated into a UAV. We are using the UbiSwitch baseboard with the included cables.
We have detected some problems with the stability of the connection to the cameras. We are using 4 Basler GigE cameras and they continuously report connection and disconnection events.
Logs from Pylon viewer:
Type Time Source Message
Information 2025-10-14 11:14:05.540 basler_9596 (40642632) “basler_9596 (40642632)” has been removed.
Information 2025-10-14 11:14:05.539 basler_9598 (40642635) “basler_9598 (40642635)” has been detected.
Information 2025-10-14 11:14:05.537 basler_9595 (40639658) “basler_9595 (40639658)” has been detected.
Information 2025-10-14 11:13:55.539 basler_9597 (40639661) “basler_9597 (40639661)” has been removed.
Information 2025-10-14 11:13:55.539 basler_9598 (40642635) “basler_9598 (40642635)” has been removed.
Information 2025-10-14 11:13:55.538 basler_9595 (40639658) “basler_9595 (40639658)” has been removed.
Information 2025-10-14 11:13:25.538 basler_9597 (40639661) “basler_9597 (40639661)” has been detected.
Information 2025-10-14 11:13:15.538 basler_9597 (40639661) “basler_9597 (40639661)” has been removed.
Information 2025-10-14 11:10:45.538 basler_9596 (40642632) “basler_9596 (40642632)” has been detected.
Information 2025-10-14 11:10:35.537 basler_9596 (40642632) “basler_9596 (40642632)” has been removed.
Information 2025-10-14 11:10:15.541 basler_9598 (40642635) “basler_9598 (40642635)” has been detected.
Information 2025-10-14 11:10:15.540 basler_9597 (40639661) “basler_9597 (40639661)” has been detected.
Information 2025-10-14 11:10:15.539 basler_9596 (40642632) “basler_9596 (40642632)” has been detected.
Information 2025-10-14 11:10:15.537 basler_9595 (40639658) “basler_9595 (40639658)” has been detected.
Information 2025-10-14 11:10:05.539 basler_9598 (40642635) “basler_9598 (40642635)” has been removed.
Information 2025-10-14 11:10:05.538 basler_9597 (40639661) “basler_9597 (40639661)” has been removed.
Information 2025-10-14 11:10:05.538 basler_9596 (40642632) “basler_9596 (40642632)” has been removed.
Information 2025-10-14 11:10:05.537 basler_9595 (40639658) “basler_9595 (40639658)” has been removed.
Information 2025-10-14 11:08:35.541 basler_9598 (40642635) “basler_9598 (40642635)” has been detected.
Information 2025-10-14 11:08:35.540 basler_9597 (40639661) “basler_9597 (40639661)” has been detected.
Information 2025-10-14 11:08:35.539 basler_9596 (40642632) “basler_9596 (40642632)” has been detected.
Information 2025-10-14 11:08:35.538 basler_9595 (40639658) “basler_9595 (40639658)” has been detected.
Information 2025-10-14 11:08:25.539 basler_9598 (40642635) “basler_9598 (40642635)” has been removed.
Information 2025-10-14 11:08:25.538 basler_9597 (40639661) “basler_9597 (40639661)” has been removed.
Information 2025-10-14 11:08:25.538 basler_9596 (40642632) “basler_9596 (40642632)” has been removed.
Information 2025-10-14 11:08:25.537 basler_9595 (40639658) “basler_9595 (40639658)” has been removed.
Information 2025-10-14 11:06:55.541 basler_9598 (40642635) “basler_9598 (40642635)” has been detected.
Information 2025-10-14 11:06:55.540 basler_9597 (40639661) “basler_9597 (40639661)” has been detected.
Information 2025-10-14 11:06:55.539 basler_9596 (40642632) “basler_9596 (40642632)” has been detected.
Information 2025-10-14 11:06:55.538 basler_9595 (40639658) “basler_9595 (40639658)” has been detected.
Information 2025-10-14 11:06:35.539 basler_9598 (40642635) “basler_9598 (40642635)” has been removed.
Information 2025-10-14 11:06:35.538 basler_9597 (40639661) “basler_9597 (40639661)” has been removed.
Information 2025-10-14 11:06:35.538 basler_9596 (40642632) “basler_9596 (40642632)” has been removed.
Information 2025-10-14 11:06:35.537 basler_9595 (40639658) “basler_9595 (40639658)” has been removed.
Information 2025-10-14 11:06:05.541 basler_9598 (40642635) “basler_9598 (40642635)” has been detected.
Information 2025-10-14 11:06:05.541 basler_9597 (40639661) “basler_9597 (40639661)” has been detected.
Information 2025-10-14 11:06:05.540 basler_9596 (40642632) “basler_9596 (40642632)” has been detected.
Information 2025-10-14 11:06:05.538 basler_9595 (40639658) “basler_9595 (40639658)” has been detected.
Information 2025-10-14 11:05:55.539 basler_9598 (40642635) “basler_9598 (40642635)” has been removed.
Even ping tests are losing packets.
The Ubiswitch is connected to Jetson AGX Orin 64GB (Connectech Rogue carrier board) using a 10Gig SFP port. Cameras and Jetson are configured for use MTU 9000.
Connection problems occur both on the ground and in flight.
Do you have any idea what might be happening?
P.S.: we are currently using a Tenda TEM2010X as an alternative without any problems.
