# UbiSwitch 10G Port configuration preference?
**URL:** <https://forum.botblox.org/t/ubiswitch-10g-port-configuration-preference/40>\
**Category:** BotBlox Hardware\
**Tags:** ubiswitch\
**Created:** [August 9, 2023, 3:12am UTC](https://forum.botblox.org/t/ubiswitch-10g-port-configuration-preference/40 "2023-08-09T03:12:07Z")\
**Posts on this page:** 1\
**Showing post:** 2
<div class="post-metadata">
**Author:** ![josh\_elijah](https://yyz1.discourse-cdn.com/flex027/user_avatar/forum.botblox.org/josh_elijah/32/568_2.png) [@josh\_elijah](https://forum.botblox.org/u/josh_elijah)\
**Post date:** [August 9, 2023, 3:26am UTC](https://forum.botblox.org/t/ubiswitch-10g-port-configuration-preference/40/2 "2023-08-09T03:26:47Z")
</div>
I think what you’re asking is, is there a preference for how each three of the 10G ports on UbiSwitch is configured.
There are 3 10G ports on UbiSwitch, port 0, port 9 and port 10.
Ports 9 and 10 can operate one of three modes:
Mode 1: SGMII/1000GBASE-X/2.5GBASE-X
Mode 2: 5GBASE-X
Mode 3: SFI/USXGMII
Port 0 can operate in one of six modes
Mode 2: 5GBASE-X
Mode 3: SFI/USXGMII
Mode 4: RGMII
Mode 5: RMII
Mode 6: MII
This is a little confusing. To simplify, there are likely only a few of these modes most people will want to use these ports in.
**SFI/USXGMII** is for connecting to an external 10G SFP Module
**SGMII/1000GBASE-X/2.5GBASE-X** is for connecting to an external 1G SFP module
**SFI/USXGMII** is for connect to an external 10G copper PHY chip.
Ports 9 and 10 can be configured easily as a pair on UbiSwitch, by setting the solder jumpers directly on the board JP4 and JP5. The settings for each is shown below.
| JP4 | JP5 | Mode | For use with |
| 0 | 0 | 1000BASE-X/SGMII Mode | 1G SFP |
| 0 | 1 | 2500BASE-X Mode | 2.5G SFP |
| 1 | 0 | 10GBASE-R Mode | 10G SFP (default) |
| 1 | 1 | USXGMII Mode | External copper PHY |
By default, UbiSwitch is configured to put ports 9 and 10 in 10GBASE-R Mode, for use with an external 10G SFP. However, JP5 can be soldered, which will put ports 9 and 10 in USXGMII mode, for use with an external copper PHY.
Port 0 requires software to configure, and is by default, set to 10GBASE-R Mode.
Therefore, for an application requiring two copper PHYs and 1 10 SFP, it is recommended to use ports 9 and 10 for the copper PHYs, and port 0 for the 10G SFP.
_[View the full topic](https://forum.botblox.org/t/ubiswitch-10g-port-configuration-preference/40)._
