I am attempting to test the Ubiswitch’s 10G functionality with an external 10 GBs copper PHY on a different board. I have soldered 2 pairs of twisted jumper wires to the Port 10 TX/RX differential pairs. To accomplish this, I soldered to the vias shown here.
I wouldn’t recommend accessing UbiSwitch’s 10G ports this way. These signals run at 10.3125 Gbaud using NRZ signalling and require controlled-impedance differential connections. Soldering twisted-pair wires directly to the board’s vias is unlikely to work reliably from a signal integrity perspective, before we even get to configuring the port mode (USXGMII, 10GBASE-R, etc.).
The better approach is to use the UbiSwitch Baseboard, which brings the 10G ports out to SFP cages. You can then use a suitable SFP-to-SMA adapter to access the signals.
You also haven’t mentioned which PHY you’re using or how you’re physically connecting to it. That connection could introduce further signal integrity issues.
Please share the PHY part number, its form factor and details of the physical connection so we can suggest the best way to test this.
I understand the twisted wire solution isn’t likely to have great signal integrity, but this test is being done as a proof of concept just to see if the functionality is possible, before designing a custom board around it. The speed of data transfer is currently not a priority for the test. As such, I believe the twisted wire solution is ok.
I actually have a Ubiswitch Baseboard on hand, however I do not want to use the SFP cages for the 10G lines because I’d like to access the port 10 signals before they go through the PHY on the Ubiswitch/Baseboard. Again, my goal is to verify the Ubiswitch’s switching functionality when used with the external PHY.
I am using the SFP (RJ 45 connection directly to a server) for 10 GBs on the baseboard for port 2, as the output for the ubiswitch. But not for port 10.
The external PHY is called BCM84891LB0IFEBG, and I am connecting to it via the TDP/TDN and RDP/RDN pins, in series with a 100 nF cap on each line. See the diagram below:
Using twisted pair isn’t going to “just reduce the speed”. It’s likely to mash up the signal so badly that it’s just not going to work; in other words, no link. This is a 10.3125GHz signal, it’s generally not going to be ok with soldered twisted pair wires.
In my opinion, there’s no point in debugging anything else if the signal itself is mashed to hell.
On the UbiSwitch Baseboard, there are no PHYs on the 10G lines. They route directly from the UbiSwitch module to the SFP cage contacts; it’s a direct connection.
Please tell me the physical form factor that your BCM84891LB0IFEBG is housed on. Is it a custom board? A dev kit? What physical connectors are exposed on that for the 10G?
It is housed on a custom board. I am currently soldering to the pads of the 0402 capacitors in the diagram I showed there. I could also access that connection through certain pins of this connector 3-5353652-6:
Without desiging a custom board, which would take time, I would try the following…
I would do it like this…
UbiSwitch Module → UbiSwitch Baseboard SFP cage → SFP to SMA breakout board (like this) → Very short (<50mm) SMA cables → soldered directly to capacitors on your custom board
This is not guaranteed to work either though, arguably the signal integrity might not be that much better from what you’re already trying.
Sadly it’s difficult to test this without just building the baseboard for UbiSwitch.
That said, I’ve taken a look at the BCM84891LB0IFEBG chip. It’s a 10G Copper PHY that supports 10GBASE-R/XFI as well as USXGMII; both modes that UbiSwitch support. UbiSwitch works in 10GBASE-R/XFI mode out the box.
Some things you could try immediately with your current setup.
Try putting the 10G ports on UbiSwitch into USXGMII mode using our BloxOSLite software.
Check the mode of the Broadcom PHY, do you have access to it’s MDIO bus so you can read/write internal registers? Is the Broadcom PHY in USXGMII mode or is it expecting 10GBASE-R?
If you have access to the MDIO bus on the broadcom PHY, can you read any status registers for its MAC port? It may report any errors on the 10G MAC port directly.
Does the Broadcom PHY require firmware to be loaded onto it? Have you tried that?
