# Is there a board mount version of GigaBlox?
**URL:** <https://forum.botblox.org/t/is-there-a-board-mount-version-of-gigablox/97>\
**Category:** BotBlox Hardware\
**Tags:** gigablox\
**Created:** [October 26, 2023, 12:27pm UTC](https://forum.botblox.org/t/is-there-a-board-mount-version-of-gigablox/97 "2023-10-26T12:27:12Z")\
**Posts on this page:** 1\
**Showing post:** 2
<div class="post-metadata">
**Author:** ![josh\_elijah](https://yyz1.discourse-cdn.com/flex027/user_avatar/forum.botblox.org/josh_elijah/32/568_2.png) [@josh\_elijah](https://forum.botblox.org/u/josh_elijah)\
**Post date:** [October 26, 2023, 12:47pm UTC](https://forum.botblox.org/t/is-there-a-board-mount-version-of-gigablox/97/2 "2023-10-26T12:47:10Z")
</div>
In general, we would suggest customers to use GigaBlox Nano if they need a board mountable gigabit switch.
It is a common ask if GigaBlox can be board mounted. Usually this is because GigaBlox has five ports, and those ports already have transformers present.
Nearly all of our boards use connector footprints that allow either Molex Picoblade 1.25mm (cable mating) or Harwin 1.27mm vertical pin headers. This means that all of our boards can be converted to board mount simply by changing the connector.
**On GigaBlox**
Harwin [M50-3530842](https://www.harwin.com/products/M50-3530842/) can be used for the ports and [M50-3530442](https://www.harwin.com/products/M50-3530442/) for the power.
**On the mating board**
Use the female part, Harwin [M52-5010845](http://m52-5010845/) for the ports and the [M52-5010445](https://www.harwin.com/products/M52-5010445/) for power.
The total height of the male and female assembled connectors would be 9.51mm, which exceeds the 7.3mm height of the transformer. This means it could be stacked onto the mating board, as long as there was no component higher than 2.21mm underneath the transformer. Below is an image.
 ![image](https://canada1.discourse-cdn.com/flex027/uploads/botblox1/original/1X/e3968a653152803306f0fe7545a4b6cdb37f1c46.png)
In terms of a footprint for this component, we don’t have one yet, so just use the DXF for the standard version ([here](https://botblox.io/content/GigaBlox_Rev_C)).
3D Model is in the link below.
> **[Free CAD Designs, Files & 3D Models | The GrabCAD Community Library](https://grabcad.com/library/gigablox-harwin-variant-1)**
> The GrabCAD Library offers millions of free CAD designs, CAD files, and 3D models. Join the GrabCAD Community today to gain access and download!
In terms of ordering this component, it’s not something we stock yet (though I expect we’ll start stocking it soon).
That means it’s either an MoQ job (usually around 20 pcs), or you’ll need to replace the connectors yourself.
_[View the full topic](https://forum.botblox.org/t/is-there-a-board-mount-version-of-gigablox/97)._
